Hello Guest it is October 02, 2026, 08:39:08 AM
Author Topic: NEED HELP motor sound but no movement  (Read 12913 times)
« on: May 18, 2015, 06:03:32 PM »
Hello!
I'm building a controller with 3 single axis tb6560 drivers, the breakout board that came along and 24v 6.5 amps powersupply to control 3 nema 23 185oz/inch 2a
Every thing seems to be working but when i configured mach3 and tried to make the motors jog and the motors sound like they are moving but they aren't.
I'm thinking it might be a configuration that isn't right but i'm kinda new to cnc and don't know what to change.
If any info is missing let me know.
Simon
Offline Vogavt
  •  260 260
Re: NEED HELP motor sound but no movement
« Reply #1 on: May 18, 2015, 07:17:19 PM »
Upload your xml file so we can take a look.
« Reply #2 on: May 18, 2015, 07:23:50 PM »
xml file as asked.
Wish someone can help me as i've been on this all week-end.  >:D
Simon
Offline Vogavt
  •  260 260
« Reply #3 on: May 18, 2015, 08:11:53 PM »
Looks like you're using the same pins for one of your axis and an output. Specifically pins 8 & 9.
I also see you have flood assigned to Pin 7 and Z-axis Dir pin as 7
Go back through the Ports & Pins and clean up the anomalies first.
Are you in Demo Mode?
« Reply #4 on: May 18, 2015, 08:22:25 PM »
Yes, I am in demo mode for test purposes.
« Reply #5 on: May 18, 2015, 08:30:12 PM »
i'm not too sure what you mean about pin 7 having flood assigned.
As posted earlier i'm kind of new and don't know much either about cnc.
« Reply #6 on: May 19, 2015, 05:17:10 PM »
I cleaned out my anomalies.
But now all i'm getting is a sound when i jog but no movement.
I've been searching the web since yesterday to find a solution.
Still haven't found the solution.
Thanks in advance,
Simon
ps. cleaned profile loaded.
« Reply #7 on: May 20, 2015, 06:44:57 PM »
nevermind find my problem was the 4pin wires that come along with they tb6560 driver.
Thanks.
