Hello Guest it is February 27, 2025, 08:46:31 PM
Author Topic: Mist control  (Read 4278 times)
Offline midyo
  •  14 14
Mist control
« on: May 22, 2015, 04:07:08 PM »
Well, after many hours searching to no avail, can someone please tell me the keyboard shortcut for mist control on mach 3 please? (not flood)
Re: Mist control
« Reply #1 on: May 22, 2015, 06:00:53 PM »
I don't think there is one set up for mist, you would have to open the screenset in one of the screen designer programmes and add one.
Offline midyo
  •  14 14
Re: Mist control
« Reply #2 on: May 23, 2015, 07:15:51 AM »
Thanks Hood, is that a short/easy enough task for you to tell me how please?
Re: Mist control
« Reply #3 on: May 23, 2015, 02:48:32 PM »
Go to http://www.kd-dietz.com/ and download the machscreen software.
Install the software and open it.
Open your screen file (usually under mach3 main folder).
Found the Mist Button and click on it.
There will be a one more window for settings dro and buttons oem codes etc. Go to there and click on hotkey after press a button on your keyboard which button do you want to setup hotkey for mist.
Save screen and open mach3.
Offline midyo
  •  14 14
Re: Mist control
« Reply #4 on: May 24, 2015, 09:23:32 AM »
thanks
