Hello Guest it is November 25, 2026, 04:49:27 PM
Author Topic: Spindle wont turn back on.  (Read 9253 times)
« on: July 22, 2015, 03:43:44 PM »
Hey guys. Me again. Getting the bugs worked out of the new to me machine. Its a 07 shopmaster bridge mill.  The spindle turns on when i start a job but if theres a proble and i stop it by hitting the stop button or estop and try to restart the spindle wont come back on. Is there a setting or something that i need to check. Thanks for the help.
  •  9,378 9,378
Re: Spindle wont turn back on.
« Reply #1 on: July 23, 2015, 06:43:22 AM »
I am presuming the spindle is started with an M3 command at the beginning of the Gcode. If you stop and then re-start the program run you need to click on the Spindle button (or use F5, or other methods etc.) and allow the spindle to run-up to speed before clicking on Start.
« Reply #2 on: July 24, 2015, 10:26:15 PM »
Ok ill try that see if it works. Thanks.
« Reply #3 on: July 26, 2015, 03:21:31 PM »
That worked thanks.
