Hello Guest it is December 26, 2024, 10:35:35 AM
Author Topic: new cnc router problems  (Read 3832 times)
« on: July 30, 2015, 05:08:28 PM »
I am a newbie and just got a x6-2200L usb cnc engraver. It has a usb controller and i am running mach 3. I can not get mach3 to work. i know it is vague but it does nothing so i dont know where to start. the instructions were terrible
Re: new cnc router problems
« Reply #1 on: July 30, 2015, 05:21:33 PM »
I would suspect the USB setup. What USB breakout board is being used?
How long are the USB cables?
Are you sure the USB port that you are using is working?
Is it USB 2.0 or 3.0?
Do you see the digital Inputs such as the emergency stop switch.
« Reply #2 on: July 30, 2015, 05:27:19 PM »
I would suspect the USB setup. What USB breakout board is being used? I have no idea the control box for the machine is already set up for usb not parallel
How long are the USB cables? standard legth
Are you sure the USB port that you are using is working? YES
Is it USB 2.0 or 3.0? 2.0
Do you see the digital Inputs such as the emergency stop switch. there is an energency stop button i have checked that it is good
« Reply #3 on: July 30, 2015, 05:34:28 PM »
Are there any LED's on the USB board that indicate coms or I/O?
I have just had some issues with a CNC router that I have converted and it turned out to be a problem with the PC.
« Reply #4 on: July 30, 2015, 05:45:46 PM »
took the cover off the controller and usb card has red blinking light
« Reply #5 on: July 30, 2015, 06:30:37 PM »
That normally indicates that the USB coms are functioning. If you try and jog an axis you should see it blink faster. The machine should move at the same time.
I will be away from my PC now as I have to go to a customer. Don't know where you are but I am in New Zealand which means my time zone is out of sync with most other members.
