Hello Guest it is September 22, 2026, 10:31:49 PM
Author Topic: lazyturn fine profile  (Read 77626 times)
« on: August 12, 2015, 07:11:20 PM »
Need help.  When i create a rough profile on lazy turn it seems to work perfectly but when i add the fine profile that profile looks correct in lazyturn but the code cuts about twice as deep on the x.
Re: lazyturn fine profile
« Reply #1 on: August 15, 2015, 10:40:06 AM »
here is a picture of my file in mach3.  any help would be appreciated
« Reply #2 on: August 15, 2015, 11:37:28 AM »
You appear to be mixing Dia. and Rad. modes.
You must do everything in the same mode.
See the instructions by RICH in the docs. section.
Russ
« Reply #3 on: August 15, 2015, 12:08:09 PM »
Thanks Russ,
« Reply #4 on: August 15, 2015, 12:26:55 PM »
dia mode vs rad mode.
Figured out my problem with help from Russ, but can't find in the manual how to fix this.  I see how to turn diameter mode on and off but not how to turn it on/off between rough or fine cuts.  When i uncheck diameter mode the program works fine but when in diameter mode the rough cut is correct but the fine cut is still in radius mode. is there a fix for this or do i just need to keep it in radius mode?
Thanks.
« Reply #5 on: August 15, 2015, 06:35:17 PM »
« Reply #6 on: August 18, 2015, 05:29:41 PM »
Thanks again Russ.
Radius Mode it is.  Everything is working fine.
