Yes... I see many easy ways to oops..lol.
I agree that the lathe could be significantly more dangerous, especially being the spindle is a large spinning mass verse an endmill. I ALWAYS get nervous when the tool starts getting close to the chuck.. I watch the sims and know it will stop, but it is still a bit of a pucker factor no matter how many times I see it safely clear..hahaha
I did notice that grooving works great with a zig zag option I found in Camworks especially if it's a wide groove. It goes in a set depth then moves axially to the other edge and goes in the set depth again and back the other way and continues to the part geometry depth in X. Definitely helps with the chatter.
I did find that 600rpm is perfect speed for grooving and parting off, excellent advice Hood! I set feed for .001 FPR and it still chatters a little but but not nearly as bad.
I also found that parting off close to the chuck really makes a big difference. Almost eliminates all chatter and I was running .004 FPR with a nice smooth material peel. I think it is because of several factors on my machine, for one the table mounted tool post is closest to the base so there is less deflection of the table and the material is closest to its mounting point.
All in all I call it a success.. Now I'm just digging deeper into the CAM software to find all of its nifty secrets, and there are quite a few.
The technology database has taken some time to figure out but now that I see how it works it is very powerful, and I love that it is completely configurable. So for example, for ID Profiles, it has cored or solid parameters and for every various diameter o the ID profile it allows a configuration to be defined. So for a 1" ID hole, I can program the auto feature recognition to call strategy #********* which has a center drill strategy with tool X, a drill strategy with tool Y, a bore rough strategy with tool Z, and a Bore Finish strategy with tool A. All of which pull from cutting parameters for each of those strategies. Once you define those strategies for your machine but automatically recognizes the ID feature, generates an operation plan with all of the above strategies and then kicks out a tool path. So it completely builds the machining plan and if all your setting are properly entered, it is done and ready to spit out a post.
Obviously setting all of the configurations takes time. But the tech database does have a wonderful copy function that allows you to copy a finished strategy parameter and paste it to another operation so it isn't too bad. But for now I find it is easiest to set them up as I get to parts with features i haven't had before.
Sent from my XT1080 using Tapatalk
