Hello Guest it is September 01, 2024, 02:15:53 AM
Author Topic: Can i change the Pulse engine parameters without the Pokeys Program ?  (Read 13301 times)
Offline NeoTO
  •  504 504
    • PoLabs
Re: Can i change the Pulse engine parameters without the Pokeys Program ?
« Reply #10 on: December 07, 2015, 12:09:40 AM »
Hi, Gerd
Mach3 plugin will not 'harm' the PoBlocks program, but I would suggest to implement some mechanism (like a signal from a physical switch) to block the PoBlocks program from affecting the Pulse engine - unpredicted behaviour can occur if both PoBlocks and Mach3 are commanding the motors.
