Hello
Guest
it is
July 27, 2024, 08:38:30 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach 3 demo prg
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 3 demo prg (Read 2180 times)
mickmagnum
2
Mach 3 demo prg
on:
September 27, 2015, 11:44:07 AM »
Hello all
Will the demo prg allow you to run a machine albeit restricted
Mick
Logged
ger21
6,295
Re: Mach 3 demo prg
Reply #1 on:
September 27, 2015, 12:37:36 PM »
Yes, but limited to 500 lines of g-code, and a few features that are disabled, like Run From Here.
Logged
mickmagnum
2
Re: Mach 3 demo prg
Reply #2 on:
September 29, 2015, 12:09:09 PM »
Thanks for that Gerry
My problem now appears to be with the parrell port not communicating with the Breakout board the stepper motor is all wired correct .
Using Windows XP on a tower the software is loaded the drivers are ok and the axis movement records on X Y Z
Many thanks for your help to date
Mick Magnum
Logged
jimthefish
303
Re: Mach 3 demo prg
Reply #3 on:
September 29, 2015, 12:23:59 PM »
Take it your still having problems, so have you selected the correct parallel port in the config settings and checked the driver is giving the correct pulse.
Logged
Print
Pages:
1
Go Up
« previous
next »
