Hello Guest it is September 15, 2026, 02:38:14 AM
Author Topic: Mach4 Install on XP  (Read 32531 times)
Offline TDAY
  •  165 165
    • Home CNC Stuff
Mach4 Install on XP
« on: December 10, 2015, 01:02:55 PM »
Trying to install Mach4 on a windows XP machine. After install, i try to launch Mach4 and get an error stating"Could Not Initialize the Core".
This is a 32bit windows Home XP that i just did a fresh install of OS today.
I havent been keeping up with the development of Mach4 (starting a new chapter) , so does Mach4 Ver 2 work on XP?
Troy
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Offline dude1
  •  1,253 1,253
Re: Mach4 Install on XP
« Reply #1 on: December 10, 2015, 04:58:03 PM »
try installing as admin it seems that is a problem at the moment with xp machines
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #2 on: December 11, 2015, 06:07:27 AM »
User is set as admin. Also forgot to mention after closing the first error message, i get another stating 'There was a problem loading the screenset "" '.
« Last Edit: December 11, 2015, 06:09:53 AM by TDAY »
Offline dude1
  •  1,253 1,253
« Reply #3 on: December 11, 2015, 03:23:54 PM »
do you start as admin
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #4 on: December 11, 2015, 04:30:00 PM »
Yup.
Offline dude1
  •  1,253 1,253
« Reply #5 on: December 11, 2015, 04:34:00 PM »
can you put it on line and run update's you may have something missing, and yes window update still works for xp
« Reply #6 on: December 12, 2015, 10:29:03 AM »
do you have .net framework 3.5 and vcredist 2013 installed?
Offline TDAY
  •  165 165
    • Home CNC Stuff
« Reply #7 on: December 12, 2015, 09:28:06 PM »
No, there is no .net nor vcredist 2013, unless Mach4 installed them. Ill check it out Monday and post my results.
Troy
« Reply #8 on: December 12, 2015, 09:51:52 PM »
I think those requirements only apply if your are trying to use the legacy Darwin parallel port driver.
Steve Stallings
www.PMDX.com
« Reply #9 on: December 12, 2015, 10:32:54 PM »
Mach4 uses the .net for sure........ not sure about the vcredist.
