Hello Guest it is September 23, 2026, 02:43:29 AM
Author Topic: VB Script to buttons...  (Read 15756 times)
« on: December 13, 2015, 10:47:42 AM »
Is there a way to 'Execute a Basic Script' to a button, but as a TOGGLE instead of two separate On/Off buttons and two
scripts?
I have a switch that I would like to run my dust extractor with....and I have set the Basic Script to ActivateSignal(OutPut2), which
works fine.  But I also need to turn it off...but preferably with the same button!
I guess I cannot do it with one button, but will need a second button to run DeActivateSignal(OutPut2)..??
Re: VB Script to buttons...
« Reply #1 on: December 13, 2015, 05:09:42 PM »
if not isactive then
activate
else
deactivate
end if
« Reply #2 on: December 18, 2015, 04:33:56 PM »
Hi Gerry,
Thanks for the reply.  I've tried the script but get an error!  "Error on Line 1 - Argument not Optional"
I have checked that it's correctly spelled.  The 'Isactive' doesn't turn blue after I've typed it in the scripter...is that the problem?
This is what I have...
If Not Isactive Then
ActivateSignal(Output2)
Else
DeActivateSignal(Output2)
End If
Apologies for my ignorance...still learning this stuff!
Keith
« Last Edit: December 18, 2015, 04:38:11 PM by krsykes23 »
« Reply #3 on: December 18, 2015, 06:11:45 PM »
If Not Isactive (Output2) Then
Else
End If
I use similar but this way ...
If IsOutputActive(OUTPUT2) Then
DeActivateSignal(OUTPUT2)
else
End if
« Reply #4 on: December 19, 2015, 11:18:38 AM »
Hi Overloaded....worked a treat.  Thanks for the help!
