Hello Guest it is November 27, 2026, 12:52:37 AM
Author Topic: Confirmation on motor tuning...  (Read 9875 times)
« on: December 15, 2015, 11:10:17 AM »
I'm replacing my Threaded Rod with a 5mm Ball Screw and just wanted to verify that I'm doing the math correctly for tuning the motor with a G540 and a stepper with 200 steps per rev.
200 x 10 = 2000
2000 / 5.08 = 393.70
Adam
Re: Confirmation on motor tuning...
« Reply #1 on: December 15, 2015, 11:25:32 AM »
Hi Adam,
 5.08 ?
That would be a .200" lead, not 5mm which would be 10000 per inch or as you say 393.7 per mm.
5mm lead would be:
10160 per inch
400 per mm
Russ
« Last Edit: December 15, 2015, 11:31:06 AM by Overloaded »
« Reply #2 on: December 15, 2015, 12:30:09 PM »
yeah, caught that 5.08 in another thread... hence my uncertainty.
The Ball Screw has a 5mm pitch (0.196850394 in) not 5mm in length, I think you understood that, I should have been clearer.
So, I think this is correct then?
200 (stepper) x 10 (microstepping) / 5mm (0.196850394) = 10160
Is that correct?
« Reply #3 on: December 15, 2015, 07:04:00 PM »
Any additional information you could share on the Velocity and Acceleration entry's to start with?
