TP
most of the stuff I will be doing is in the 4mm to 20mm range in Alu and 2mm to 20mm Stainless, so the plate bending shouldn't really be an issue, or at least I hope it wont be
I asked the russian guy that I am getting the THC from, about the Ohmic sensor he sells and he said he didn't think the torch I will be getting would work with it. I may however get a machine torch at a later stage so could look at it if need be.
Rob
I looked at the 45 and thought it was a bit too small for what I need. It was a toss up between the Powermax 65 and three from TecArc, the 65, the 95 and the 125. Decided the 95 and 125 may be too big for what I want so I ruled them out.
So it was the Hypertherm 65 or the OptiCut 65, the capacity and duty cycles were about the same (the Opticut fractionally better on some).
The Hypertherm was more expensive but that wasn't a major consideration as I tend to try and only buy once. I spoke to someone who has used both and he rated the Opticut a better machine and he is a Hypertherm owner, so decided to go with it.
I am also not a big fan of Inverter technology, the lifespan tends to be lower, or certainly is with TIG. The only Inverter plasma I would consider is a Hypertherm as they get a good name for life. The Opticut however has a transformer at its heart so hopefully will be more rugged. The Tig I have certainly is more rugged than the Inverter based one I had previously.
