Hello
Guest
it is
October 06, 2024, 04:34:19 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Manual tool change with Mill Wizard and Mach 4
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Manual tool change with Mill Wizard and Mach 4 (Read 2699 times)
MitchB
47
on:
January 17, 2016, 01:15:29 PM »
How do I get the machine to stop for a manual tool change after using G code generated by Mill Wizard (e.g. for two lines of holes using two tools)
Logged
MitchB
47
Re: Manual tool change with Mill Wizard and Mach 4
Reply #1 on:
January 17, 2016, 01:25:48 PM »
I see now that I use the M6 macro.
Logged
MitchB
47
Reply #2 on:
January 17, 2016, 01:53:48 PM »
Not that simple, I guess. I put the M6.mcs from the default Mach profile into the Macros directory of the profile I am using, but it looks like it isn't called. Is there anything else I need to do?
Logged
Carnoustie, Scotland
Reply #3 on:
January 17, 2016, 02:23:44 PM »
Config menu then General Config, there is an option there to stop spindle and wait for cycle start.
Logged
MitchB
47
Reply #4 on:
January 17, 2016, 02:39:09 PM »
Not in Mach 4
Logged
Reply #5 on:
January 17, 2016, 02:41:17 PM »
Ah ok never noticed the title but then again why post here rather than the Mach4 section?
Logged
MitchB
47
Reply #6 on:
January 17, 2016, 03:23:07 PM »
I originally thought this was related to Mill Wizard, but now that I realize it's the way Mach 4 handles M6, you're right - I should post it there.
Logged
Print
Pages:
1
Go Up
« previous
next »
