Hello Guest it is September 29, 2026, 11:21:52 PM
Author Topic: Mach 3 set up for foam hot wire cutter  (Read 7133 times)
« on: February 10, 2016, 06:10:38 PM »
Hello I'm Igor. New user with Mach 3. Just started. And have many questions. Primarily would like to use program with Profili , and Dev Wwing foam . Will do some hobby foam cutting for models of airplane. I wish some one help me to guide primarily familiar to use Mach 3 with 4 axis,hot wire foam cutter. How can I set up program for manually to move each Axis and both together , just for sheet of foam to cut out of block of foam ? Would appreciate to guide me up. Thank you !.
