Hello
Guest
it is
July 05, 2025, 02:18:28 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Fusion 360
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Fusion 360 (Read 10234 times)
dude1
1,253
Re: Fusion 360
Reply #10 on:
February 15, 2016, 06:23:11 PM »
got it I will put a vid up tonight will do from center out. center hole, pockets, 3D contour then cut out
Last Edit: February 15, 2016, 06:26:00 PM by blockhead
Logged
dude1
1,253
Re: Fusion 360
Reply #11 on:
February 16, 2016, 04:07:33 AM »
found the problem with your model it was a tricky one to fix, what was wrong was the spokes and rim had become disjointed, this was what was stopping you from being able to do the tool path's required.
what I had to do was put the model and sketches into a component first this is something you should do, have a look at my youtube vids I did one on doing components
https://www.youtube.com/channel/UCuKkujqPgtKixzAdFDHjzJA
the second thing I did was change the size of the inner circle from 34 mm to 33.5 mm and set the tool paths, once's I did that I changed the circle back to 34 mm and regend the tool paths and it was all good.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
