I need help with the PWM signal from Mach3. I am hooking up a Super PID and the PWM signal is inverted. When I send a M3 S5000 I get 25,000 rpm and when I send a M3 S25000 I get 5,000 rpm. I have tried changing the Pin 14 output from active High to active Low but the signal does not invert.
Am I doing something wrong or do I have to build an inverter to go between the PWM and the PID?
Joe Lawrence
