Hello Guest it is April 03, 2025, 05:59:29 PM
Author Topic: No tool table in nfl wizard  (Read 22217 times)
« on: March 10, 2016, 04:25:27 PM »
When clicking the select tool from table button in thw nfs wizard nothing happens.  I have an extensive list of tools including drills listed which works with g code programs but in the wizard I have to manually type the tool number and diameter.  When the code is uploaded into mach 3 the tool length  and diameter offsets work.  Any ideas about how to get it to work?
Re: No tool table in nfl wizard
« Reply #1 on: October 12, 2017, 02:01:06 PM »
Did you ever get this problem resolved? I'm having the same issue and could use some help.
« Reply #2 on: October 12, 2017, 02:09:14 PM »
Nope. Still the same im a bit disappointed with the result in this forum after over 600 views
« Reply #3 on: October 12, 2017, 06:13:21 PM »
I just tried it and it worked for me.  Using Mach3 ver 062 on a Windows 10 laptop.  What version of Mach are you using?
Tom
« Reply #4 on: October 12, 2017, 09:19:13 PM »
It could happen, in fact there are 1000's of users in here and would have thought that someone
would reply.......................
anyway......................
Haven't used the NFS Wizards in a "long" time.
I believe you need to populate the tool table in Mach3 as the wizard probably gets the info from there.
Works here in version 062 of Mach3.
