I have set in the Settings screen the AutoLimit OverRide but when I jog any axis and hit a limit, the machines stops, the status line says limits switch triggered but then I can’t jog out (I get the windows which says to fix it, I click fix it and still can’t backout)
When I trigger any limit by hand, it works like it should and in the diagnostic screen I have no lit LED. Estop and Probe works
All limits are set to Active Low (Green) and if I set them to Active High (Red) triggering any by hand non works.
Where should I look to fix the problem?
