Is there a way to have Mach set G54 at the end of each job?
My reason -
I have a production part, uses a small fixture that is always mounted in the same place on my mini-mill so it seems setting G55 as my work offset makes sense.
AFIK Mach always uses G54 as the default work offset, which is fine, but once i run my parts (which call G55 at the start of the code) it will remain in G55 so forgetting call G54 again will create a mess??
So, is there a way to default back to G54 after each run so it reverts to a safe condition for other jobs??
Of course, if I'm going about this backwards then please let me know but this makes sense to me so far
![Wink ;)](https://www.machsupport.com/forum/Smileys/default/wink.gif)
