I've tried to contact Bob Campbell several times over the past week and a half and am awaiting a relpy and don't know how to contact Sound Logic but I want to get my mill running. If anyone has experience with this board and can make any suggestions it would be appreciated.
I have a PC2CNC Combo board Rev 2 and I'm trying to get the spindle running. I think I have the outputs/spindle controls in Mach 3 set up right but I'm not getting the desired results.
The charge pump relay is connected to a 'master' relay that shuts off all 3Ø power just past the disconnect and fuses. If the charge pump
isn't activated the spindle and coolant will not operate.
When in MDI:
M3/F5 (RUN relay)nothing happens
M4 (DIR)the relay turns on and the LED lights
M5 turns off relay and LED turns off
M8/^F (coolant) relay turns on and LED lights
M9/^F turns relay and LED off.
In the ports and pins settings I have;
Output #1 enabled port 1 pin 1 Active high (I checked pin #1 and I'm getting 4.21 volts to ground)
Output #2 enabled port 1 pin 14 Active high
Output #3 enabled port 1 pin 16 Active high
Relay control;
M3 Output #1
M4 Output #2
M7 Output #3
M8 Output #3
Thanks in advance for any input on the problems I'm having.
LaVerne
