Hello Guest it is July 01, 2026, 08:15:20 PM
Author Topic: Cant command any movement after homing  (Read 9724 times)
« on: June 09, 2016, 02:14:04 AM »
Another issue beyond MPG I have is that the machine finds home nicely and this all works as it should, but I can not command any movement trough MDI after that . I can jog and MPG no problem turn outputs etc, but it will not move with G0 G1.
If I press STOP it says, machine motion stopped, please reference machine.... After that everything works but the machine is derefed (machine coordinates are still correct thou).
My first thought was it has something to do with soft limits but turning them off does nothing. Another one was that the load on the device is at peak, so I turned down the communication speed to MEDIUM and it dropped to around 60% . It did not help. This is all the same after I updated to new plugin from 29 may.
Re: Cant command any movement after homing
« Reply #1 on: June 14, 2016, 06:27:59 PM »
After installing .066 build Mach3 this issue is gone
I never used 066 because everyone suggested its buggy so I did not even try it, always used 062
