Hello Guest it is September 20, 2026, 06:03:05 PM
Author Topic: Macro M3 M5 for Mach3 to use for Proma SD THC plasma CNC  (Read 19627 times)
« on: July 24, 2016, 03:32:38 AM »
Dear plasma users,
would you be so kind to give some hints on how to use M3/M5 G-code commands or modify the macro to use with Proma SD thc plasma controller?
A floating head to detect the material is used with a switcher (MACH3 program for the detection of material – is configured the switch as the PROBE input signal.)
How do you do it, what g-code/macro have you used? Did you test it with Proma SD torch height controller?
Thank you,
Stan
« Last Edit: July 24, 2016, 03:38:55 AM by stan »
