Hello Guest it is September 21, 2026, 08:49:53 AM
Author Topic: CNC Y-axis is out of WACK! HELP  (Read 7223 times)
« on: September 20, 2016, 04:21:40 PM »
In the past couple of months we've been having problems with errors in our z-axis...it ended up being a faulty cable. we replaced the cable today and it worked...and the machine appeared to being working fine.....but, now, all of a sudden I got an error on the y-axis while doing a tool change and NOW, the machine thinks the y-axis sensor is about 19inches away from where it actually is.
Z and X home just fine.
I'm hoping there's some way of doing a system re-set? or y-axis reset?
It's saying things like "Can't leave home dog" and no matter what we do it thinks the Y-axis home is 19inches up the table and not at the end of the table.
Is there anything you can suggest?
It's a syntec controller with delta parts inside and delta motors on a precix cnc
ryan
