Hello
Guest
it is
September 24, 2026, 03:17:14 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
Changing Charge Pump frequency
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Changing Charge Pump frequency (Read 11625 times)
BlackElle170209
17
on:
October 13, 2016, 07:49:38 PM »
HI
Planning to use a 57CNCdb25 USB to parallel port unit on my existing parallel port connected CNC machine.
Have just realised I’m possibly going to have a problem with incompatible charge pump frequencies.
The 57CNCdb25 generates a 5KHz signal but the breakout board that it will interface to rquires a 12.5KHz input signal.......................
Does anyone know if it’s possible (and how it can be done) to change the 57CNCdb25 charge pump to generate a 12.5KHz output?. I’m hoping it would likely be a simple software change.
Can anyone help please?
Richard
Logged
NeoTO
504
Re: Changing Charge Pump frequency
Reply #1 on:
October 23, 2016, 12:24:48 AM »
Unfortunately, not. It is generated in a complex routine that runs at 10 kHz. Most charge-pump controllers will be 'satisfied' with 5 kHz, some very delicate will have problems.
Logged
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
BlackElle170209
17
Reply #2 on:
October 24, 2016, 10:24:28 PM »
Thanks for the reply - the 5KHz charge pump is not too much of a problem. I built a switched 12.5KHz oscillator using a LM555 IC to replace the 5KHz charge pump and I can see that will work fine for the setup I have here.
Richard
Logged
Print
Pages:
1
Go Up
« previous
next »
