Hello Guest it is December 22, 2024, 12:42:18 PM
Author Topic: power outage problem  (Read 2822 times)
« on: December 11, 2016, 02:59:02 PM »
Hi...after power outage ,one motor is not working...is therea reset for drivers..bob?....thanks
Offline Davek0974
  •  2,606 2,606
Re: power outage problem
« Reply #1 on: December 11, 2016, 03:06:46 PM »
not usually, just full power-down and restart, check your fuses/mcb's etc.
« Reply #2 on: December 11, 2016, 03:10:46 PM »
Thanks,  do the drivers usually have fuses?....what is mcb?...pardon my ignorance
Offline Davek0974
  •  2,606 2,606
« Reply #3 on: December 11, 2016, 04:38:37 PM »
No idea what system you have but there usually is a fuse or Magnetic Circuit Breaker (like a fuse but one that can be reset over and over, looks like a switch) in the supply somewhere. If there is none then it looks likely a drive has blown, the fact that other axes are working looks this way.
« Reply #4 on: December 11, 2016, 05:05:53 PM »
thanks for your help...i'll look for fuse or mcb tomorrow...
