Hello Guest it is December 22, 2024, 12:32:30 AM
Author Topic: Adding usb relays in Mach3  (Read 2231 times)
« on: December 12, 2016, 01:50:01 AM »
Hi all
I am using mach3 in my scara robot. Now i want to add 2 KMtronic USB relays to control the 2 grippers. Actually it is a single channel relay. I have downloaded the DLL file can controll one by using M3&M5 ( as per their manual ).  How to control the other relay? I tried by M8 & M9 . but i couldn't. Please help me in this.
And also i want the mach 3 to send a signal to another pc ( mach 3)  to control these two relays separately. Is it possible? If yes how?
Thanks a lot in advance
Re: Adding usb relays in Mach3
« Reply #1 on: December 12, 2016, 12:51:00 PM »
Write a macro for each relay, and call them from either buttons or M codes.
http://info.kmtronic.com/mach3-and-kmtronic-usb-relays.html
