OK the Mrpm@80v=3000, @.026v/rev , then 130v=5000rpm. I am not sure I would run the motor at that speed for long.
?? You can always adjust the span voltage on the digispeed to limit the top rpm on the motor
If you have a 2:1 stepdown ratio (largest pulley on the spindle)then at the rated rpm of 3000 then you have a spindle rpm of 1500rpm
you set the pulley speed at 100 low 1500 top at a base of 5.75% that should give you a low speed of 100rpm min and limit you to 1500 top rpm. s100-s1500
Since you only have one pulley ratio you only need to set 1 pulley setup
First you probably need to download a fresh copy of mach and do an install to clear up any possible problem there. Make sure you save a copy of the xml file as a backup. also if you are using a screenset other than 1024 then back it up also. then reinstall mach. I will find my manual on the speed controller and double check the digispeed manual and the mach manual and we will start from scratch.
YOu can only use 1 pulse per rev with the index option. for multi pulse you have to use the timing option. Lets stick with 1 pulse for now until we get that working ok. YOu really only need the multi pulses if you are going to run the spindle under pid control it gives it more signals per rev to work with. Can be a real pain to set up if you are not familar with pid tuning.
