If you want to improve the CV result in 2.5D and 3D Engraving/Carving you must have the same acceleration in the X/Y/Z axis.
I had a different one for the Z axis.
When I and made them all the same, then a CV 100 settings on all 180 Angles became acceptable.
The spacing between lines is .02mm with a .01mm tip cutter being used.
Next I will try it on small lettering.
Mauri
