Hello Guest it is December 14, 2025, 08:55:25 AM
Author Topic: G28.1 plasma touch off issue  (Read 37307 times)
Re: G28.1 plasma touch off issue
« Reply #10 on: December 01, 2023, 01:01:14 AM »
I have the same problem, did anyone discover a solution?
Offline TPS
  •  2,614 2,614
« Reply #11 on: December 01, 2023, 01:48:35 AM »
IMHO you have a "flickering" limit switch signal witch will not see on diagnostic screen.
you can play arround with debounce setting for test.
« Reply #12 on: December 01, 2023, 01:51:09 AM »
Ok that sounds like a good thought.  What or where are the debounce settings?
Offline TPS
  •  2,614 2,614
« Reply #13 on: December 01, 2023, 01:52:54 AM »
Config -> General Config -> upper right corner -> Debounce Interval
« Reply #14 on: December 01, 2023, 01:55:04 AM »
Ok thank you very very much, i'll give that a try.
« Reply #15 on: December 08, 2023, 02:03:59 PM »
SOLVED.. Thankyou TPS
My problem was the z-axis limit switch, it had one lead very loose, i re-crimped it and everything works as it should.
Once it got worse i could see in the diagnostics screen that it was showing that it was tripped even when the torch was in the air.
have a great day.
