Greetings from Greece.
Hi there. I have converted my SIEG X2 mill to cnc using Syil's coontroller box, running licenced Mach3 v2xx65.
I made my own metric.xml and everything run beatifull, untill today when I always get the error message:
"Your Reset command is failing due to an external influence. Either your Reset button is on, or your Limits switches are active. This can be corrected by..."
I am sure that nothing is on, I even have disconnected all inputs from the parallel break out box. Parallel port cable is the same as before, have tried in different pcs but I still cannot communicate via the lpt1 port.
Any ideas?
