Hello Guest it is March 13, 2025, 08:16:55 PM
Author Topic: Hot key code  (Read 3775 times)
Offline CNCDK
  •  23 23
Hot key code
« on: May 09, 2017, 03:24:58 PM »
How do I find Hotkey code on eg "cycle start" <Alt-R> and "Feed Hold" <spc>
Re: Hot key code
« Reply #1 on: May 09, 2017, 05:03:53 PM »
you could use MachScreen, select View -> Hotkeys and all assigned hotkeys will be listed.
Klaus
The brain isn't a soap, it doesn't shrink when used.
Offline CNCDK
  •  23 23
Re: Hot key code
« Reply #2 on: May 09, 2017, 05:57:53 PM »
Where do I find  MachScreen
Re: Hot key code
« Reply #3 on: May 10, 2017, 02:26:27 AM »
you can download it from here: www.kd-dietz.com/klausphp/ program downloads
Klaus
Offline CNCDK
  •  23 23
Re: Hot key code
« Reply #4 on: May 10, 2017, 03:09:44 AM »
