one thing which I have not really addressed in my recommendations to you regards external controllers to replace the existing one
is spindle speed control.
The real question is what spindle control you actually need. Your pics show a VFD and guess that you have a high speed spindle, maybe
24,000 rpm and 2kW output or thereabouts. Further I assume you will be doing routing with this machine. If you want to do metal milling,
and by metal I mean steel or tougher, then not only does the spindle lack the torque but the machine lacks the rigidity to contain the
cutting forces ie not suitable for it.
When I built my mill, and it is a mill, very small but rigid for metal cutting I bought a high speed spindle, 24,000 rpm 750W which I thought
would be plenty. I have used it extensively for routing, circuit boards in particular, but as a metal cutting spindle it sucks! It just doesn't have
the torque to spin reasonable diameter tools at modest speeds. So for my spindle I find that when I use it I just set it to max rpm and leave it,
after all the ONLY use it gets is routing with micro-endmills or engraving bits. Niether do I require clockwise/counter clockwise direction control,
do you have any LH cutting tools or drills or whatever? All I require is on/off.
I, like many other spent a lot of time shagging around trying to get spindle control just so, accurate speed and direction, accel and deccel etc.
In the event I was wasting my time, with the spindle I have and the work I do with it all I require is On/Off. If I want to spin a particular tool
more slowly I can manually adjust it and 99 times out of 100 leave it like that for the entire job.
My recommendation is, at least to start with, is just on/off control, the PMDX 416 for instance has a relay on board for just this purpose.
I have recently built a spindle for my mill, 3500 rpm, 1.8kW and 6.5Nm, for milling steel. Works a treat but find that I don't actually need much speed
control with it either. Unless I'm putting a large diameter facing tool or flycutter or similar I usually set it at max speed and leave it. Again without having
LH tools or drills not worried about direction control either. This spindle motor is an AC servo so I have quite a rich selection of speed control including
indexing for threading available by virtue of the servo drive but in actual use don't need any of them.
Until you get plenty of hours of actual use under your belt don't go overboard in terms of time of expense with spindle control. You may find as I did that
you don't really need all that refinement or what you really need is something entirely different.
