Hello Guest it is March 13, 2025, 07:51:41 PM
Author Topic: MACH STOPPED WORKING  (Read 3800 times)
« on: June 18, 2017, 06:21:52 AM »
I am using MACH3 under Windows 7 with Mach3-USB-3-Axis-CNC-Motion Control Card Breakout Board 2MHz. I made the setup and everything was
working perfectly. Suddenly the system stopped working, completely frozen. Motors, drivers, and card seem to be working fine. I noticed that MACH 3 main screen is frozen, not even able to move the axis in the screen
with the virtual jog, if I start a simulation with a toolpath uploaded, it does not run.
I tried to install again Mach3, even using another computer, Mach3 behavior is the same. Any suggestion will be highly appreciated.
Thank You
E.
Re: MACH STOPPED WORKING
« Reply #1 on: June 19, 2017, 10:31:00 PM »
Does the another computer running on Windows 7 as well?
« Reply #2 on: June 20, 2017, 03:25:21 AM »
Yes, both computers have Windows 7.
E.
« Last Edit: June 20, 2017, 03:27:03 AM by eqrico2017 »
« Reply #3 on: June 21, 2017, 07:58:47 AM »
i have the same on XP machine
