The velocity in motor tuning is in degrees/min, so the A velocity should be much higher than the velocity of your other axis.
In Config > Toolpath, check "Use Radius for feedrate".
On the Settings page, enter the Rotation Radius for your part. If you are setting Z zero to the center of your stock, enter .001.
