Hello Guest it is January 05, 2025, 05:01:26 AM
Author Topic: Need help with mach 3  (Read 1806 times)
« on: September 10, 2017, 01:03:16 PM »
Hi guys,
I've got a problem that I can't seem to find the answer to anywhere.
When you load your code on standard mach 3 and press start my machine moves the Z axis up 20mm to a safe position before travelling down to proceed with the cut.
Problem is I want to run a job which needs all the Z height I can get and I want to change this initial travel to 2mm or so?
Is this possible?
Cheers, Iain
Re: Need help with mach 3
« Reply #1 on: September 10, 2017, 02:23:35 PM »
can you post the first part of the Gcode... it may be that your code calls for the move that way and it has nothing to do with the safe Z
settings.
Safe Z settings are Config/Safe_Z_Setup
