Hello
Guest
it is
July 27, 2024, 11:50:56 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Scaling Question...Issues
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Scaling Question...Issues (Read 2326 times)
Billy De
92
on:
September 18, 2017, 06:36:41 AM »
Hi, Just purchased the Chinese 3040 as a back up to our Dahlgren...We use Engravelab...
For the 3040
The issue seems to be this...If we set a template 2 x 8....Save it....Convert the code etc.....
what is happening is that 2 x 8 is now 6 x 24......any suggestions as to keeping the scale 1:1 ratio?
Logged
Tweakie.CNC
9,214
Super Kitty
Re: Scaling Question...Issues
Reply #1 on:
September 18, 2017, 07:16:25 AM »
As it is 3x size you could try setting the Scale DRO's for the X and Y axes to 0.3333
Logged
Billy De
92
Reply #2 on:
September 18, 2017, 07:21:30 AM »
Thank you, That was just an example size...but thank you I will give it a shot
Logged
Billy De
92
Reply #3 on:
September 18, 2017, 07:24:07 AM »
Yep ! ! ! ! ! THANK YOU ! ! ! ! !
Logged
Tweakie.CNC
9,214
Super Kitty
Reply #4 on:
September 18, 2017, 07:57:11 AM »
Once you have established the exact scale factor it can always be incorporated into your Gcode with the G51 / G50 commands - this saves having to set the DRO's each time.
Logged
Billy De
92
Reply #5 on:
September 18, 2017, 08:03:17 AM »
Thank you...Just so used to the Dahlgren & Engravelab...Set, Send, Engrave....this is a bit different
Logged
Tweakie.CNC
9,214
Super Kitty
Reply #6 on:
September 18, 2017, 10:36:13 AM »
I don't really understand just why you have a scale issue with the 3040 - have you checked the Mach3 Steps per Unit are correct ?
Run through the Axis Calibration routine - Settings (Alt-6) page just to check you have them set correctly.
Logged
Billy De
92
Reply #7 on:
September 18, 2017, 10:51:01 AM »
Thank you, Yes...I will check...have to figure out the Z Depth as well...for nameplates and brass embossers...on the Dahlgren, we have a depth setting in the spindle ...but you have been most helpful much appreciated
Logged
Print
Pages:
1
Go Up
« previous
next »
