The default feedrate comes up as 6 IPM. Is there a way to change that?
We generally like to home to the low limit on the x-axis (left/right) and to the high limit on the y-axis (front/back). That way, the tool is out of the way so you can load material after it finds the switches. In Mach3, that seems impossible because I can only set the absolute position at the limits to 0.00. Is there a way to set the absolute coordinates to read something different? In my case, I'd like to find my limits, and then have the absolute registers set to x=0, y=73.
