Hello
Guest
it is
October 04, 2026, 12:06:36 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
X Axis hesitation
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: X Axis hesitation (Read 7204 times)
KingKerf
37
X Axis hesitation
on:
October 02, 2017, 10:44:19 AM »
I have been working with several customers that are using the Bend-Tech Dragon tube plasma cutter and running Mach3 to control the machine. We are discovering an issue where on the last cut of square tubing, the x-axis (length of tubing) is having a delay in movement when changing directions. This is causing the end cut of the tubing to not line up with itself anymore. This issue can be corrected occasionally by changing the Lead-in/Lead-out location for that cut. We have compared the g-code files for the two cuts, and the values are all identical. Are there any known bugs within Mach3 when working with 4 axis or using Inverse Time Feedrate that would cause a delay in any of the given axis commands?
Logged
Print
Pages:
1
Go Up
« previous
next »
