Graig,
'Use Spindle Feedback In Sync Mode' and 'Spindle Speed Averaging'. Haven't yet found any documentation about what those settings mean
Use Spindle Feedback In Sync Mode - required for lathe threading as Mach will then use the index to change from G94 to G95 to sync for the multiple threading paths.
The time it takes to read and implement the change can be affected by index debounce and spindle speed averaging.
Spindle Speed Averaging - Used by Mach in threading and averages the rpm
( out to 4 decimal places ) over 8 revolutions ( from what I remember when testing ) during a path and uses the result for the the next path. There is more to this and would need find and look at more than 300 pages of notes. This is internal to Mach and you have no access to it. I would just check it and forget about it.
A simple test of the spindle sync would be to use a thin disc and see the scribed
mark made by the tool on the disc's cirmference. It's also a good test to see if ones lathe is capable of doing multiple start threading. Same old remark, threading only as good as your lathe SYSTEM.
