Hello
Guest
it is
October 06, 2024, 04:27:33 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
-X AND - Y LIMIT FAULT
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: -X AND - Y LIMIT FAULT (Read 1860 times)
blauderb
9
on:
October 17, 2017, 05:27:17 PM »
Could someone explain why can't reset after a -x or -y limit fault? Every time I hit reset it just faults again, no chance to do a manual override. If it's a +X or +Y limit I can reset then back it off the limit in jog mode.
Logged
ger21
6,295
Re: -X AND - Y LIMIT FAULT
Reply #1 on:
October 17, 2017, 05:41:49 PM »
Did you click the manual override button first?
Logged
blauderb
9
Reply #2 on:
October 17, 2017, 06:34:22 PM »
axis limit override is gray out when mach 4 is disabled
Logged
ger21
6,295
Reply #3 on:
October 17, 2017, 09:04:15 PM »
Sorry, I thought you were using Mach3.
Logged
Print
Pages:
1
Go Up
« previous
next »
