Hello Guest it is April 26, 2025, 06:38:04 AM
Author Topic: Depth Not Changing in Mach3  (Read 5079 times)
« on: November 03, 2017, 11:38:09 AM »
OK New Wrinkle...I send a Job from F-Engrave to Tap File....If I set the Depth at  -.0001 or -.0125....The Depth does not change.... I am perplexed...This Just started happening today....
Billy
Re: Depth Not Changing in Mach3
« Reply #1 on: November 03, 2017, 11:44:25 AM »
Nevermind ughhhhh.....Piece was bowed.....
« Reply #2 on: November 03, 2017, 02:11:31 PM »
Hi Billy,
I make circuit boards which require extremely fine depth control even with PCB blanks that have modest bow/warps. I use:
https://www.autoleveller.co.uk/
and would be of value to anyone doing engraving.
« Reply #3 on: November 03, 2017, 02:13:10 PM »
Thanks Craig...! ! ! !
« Reply #4 on: November 07, 2017, 03:01:26 PM »
Update.... A Few Things.....Turns out that we have a 15 degree angle on Flex Bits...Not 30 degree standarrd....so getting bits re-tooled...
Our Dahlgren spindle speed goes from 3000 to 23000....and we run brass at about  11000...Reading up more ion the Mach3 software and tweeks...Once I get the Bits Back..... I can give a better update.....
Billy
« Reply #5 on: November 07, 2017, 03:52:55 PM »
Hi Billy,
yeah 15 degree bits are VERY tender.
« Reply #6 on: November 07, 2017, 04:03:29 PM »
For Plastic (Soft)...Its all Good :)...When we took over the other company....The Person who ran the Dahlgren was like me trying to run the CNC at first :)..... We went by the Specs that he initially had as far as the bits.....What he had was incorrect...
I found that out by doing a Back Check with Antares... under the other companies name....They said that ACE got 15 degree not 30.... When we would send the bits in to be re-sharpened...We always thought they were 30....But now we know  that as well :)
