if the Feed Rate Overide is active then the overide bar blinks red. The feed speed is reduced from what you've programmed, 1000 units/min
to a percentage, in your case the FRO is 4% therefore your feedrate is 40 unit/min, close to but not identical to the 34.11 units/min that Mach
calculates. It is not neccessary but it is common for the traverse speed to be affected by the FRO as well, thus your G0 (rapids or traversere) would be
2500.2 x 0.04=100 units/min, there again not quite what Mach calculated but close.
Hit the FRO <reset> and try running the code again.
