Hello Guest it is October 04, 2026, 08:31:12 AM
Author Topic: Mach 4 requirements  (Read 9754 times)
Mach 4 requirements
« on: November 23, 2017, 10:29:28 PM »
G'day. Im sure you have heard this a million times but im a Newbie to this CDC thing. Im the only one I know who is interested in it so im stumbling around in the dark a fair bit. Ive built a Mill and have it moving about using Mach 3 however I have a very basic understanding of it all. I figured that if im going to learn a new program I may as well learn to use the latest and greatest version, that being Mach4. My question is do I need to buy a new Motion Card given that my board was sold as a Mach 3 compatible board. Its a STB4100 motion card if that helps. I figured at the very least id need a new plugin however i can find no info on the subject. Any help would be greatly appreciated.
Thank
Matt
  •  9,374 9,374
Re: Mach 4 requirements
« Reply #1 on: November 24, 2017, 12:37:05 AM »
Hi Matt,
The STB4100 is for Mach3 only. To use Mach4 you need a different controller, there are many to choose from - I use the ESS and you can read-up details here https://www.warp9td.com/index.php/gettingstarted
« Reply #2 on: November 24, 2017, 01:16:52 AM »
Thanks for the prompt reply, i suspected as much. Ill have a look at the link. Thanks again
Matt
