Hello Guest it is September 29, 2026, 03:21:59 AM
Author Topic: DRI input does not work  (Read 8530 times)
« on: January 10, 2018, 08:22:54 PM »
I have restarted mach3 after about 6 years. It was installed on a Shopbot with a HICON control board coonected via ethernet to an old XP. I am trying to remember how everything worked. The axis home correctly but I am having a very strange problem with the DRI input box. I want to move each axis to verify the calibration. I can move X and Z from the config screen but the Y axis is actually two motors ( Y and A slaved ). So moving the Y using config does not move the slave and all hell breaks loose. So I decided to test the axis using G code from the DRI input box. Just type in G00 Y10.0 and it should move. HOWEVER - I can type in G00 but when I add the space and Y (or X for that matter) the input box goes blank and nothing happens. Does anybody have any idea what is going on ?
  •  9,374 9,374
Re: DRI input does not work
« Reply #1 on: January 13, 2018, 04:43:34 AM »
Which version of Mach3 are you using ?
When the MDI box goes blank do you get any message in the Status window ?
Click on History and see if that gives any clues as to what is going wrong.
