Hello Guest it is December 26, 2024, 02:44:02 PM
Author Topic: CNC Mill Travels too far on Y Axis  (Read 2179 times)
« on: January 17, 2018, 02:16:12 PM »
I recently added CNC to my RF31 Mill. While testing its ability to precisely repeat cutting a 2 inch square, I noticed that on the second pass (and on) it cuts an additional .010 on the bottom of the square along the X axis, each which is then reflected on the X axis cut along the top of the square. For each time I repeat this the path along the Bottom and top of the square becomes wider. Cuts along Y axis sides of the square stay in their original width. I have checked everything as far as offsets, wrongly tuned motors, etc, and I am stumped.
Has anybody experienced this problem and how was it resolved?
Mel Stanley, Utah
Re: CNC Mill Travels too far on Y Axis
« Reply #1 on: January 17, 2018, 03:00:18 PM »
Hi Mel,
your machine is gaining/losing steps in the Y axis.
May I suggest as an experiment swap the drive signals to the  X and Y axes stepper drivers and run the same program.
If the drivers and steppers are good the fault will stay on the Y axis and you can look closer at your Mach installation
or BoB. If the driver  and/or stepper are faulty the fault will now be on the X axis.
Gives you a means to focus on the right area.
« Reply #2 on: January 17, 2018, 04:32:32 PM »
And to add to what Craig said, this is a new install correct?  If that axis is  binding in some way or the steppers are not geared right it will miss steps.  I added CNC to my RF31  mill - drill years ago and it was very disappointing, so slow.
Retired Master Electrician, Commercial HVAC/R Service and lots of Hobbys.
« Reply #3 on: January 17, 2018, 08:04:49 PM »
Yes it is a new install with a "newbie" steering it and i might as well be blindfolded.
I thank you for your advice and thank you for posting it. At least now i have a way to isolate the problem.
