Hello to everyone!
I've got a 4 axis milling machine connected to the 6600 board, spindle is manually turned on, not connected to the board (I use the milling machine mostly for engraving brass pieces).
I've recently bought a 2W chinese laser, one of those that come with a small router, to engrave metal tags an similar things.
I've taken the laser off the original controller and thanks to a friend I've connected it to the relay and a 12V power brick.
I've found a way to turn it on with the relay and to change the "power" of it with PWM, now when I set it at S0 it turns off and S100 is 100% on.
I've modified a post processor for Aspire so that I can vary turn on and off the laser with S commands while moving the all the axis, including the Z one.
PROBLEM: when M3 is issued the steppers stop working, DRO's move but the steppers seem to be lacking power.
If I manually turn the "spindle" off (hitting F5) the steppers start working again.
Any clue?
Thanks!
