Hello Guest it is June 27, 2026, 08:41:03 PM
Author Topic: Mach3 motor outputs issue  (Read 8788 times)
« on: February 06, 2018, 02:33:16 AM »
Hello and please help.
  I have built a cnc plasma, it woks fine for a while with Mach3 trial. After I bought a license I installed Mach3 on a new Windows xp installation.  Now something  very strange is happening. My out pin assignment is like this ( for x 3-step 2-dir, y 5-step 4-dir,z 7-step 6--dir,  9-Output#1), but when I make a manual command on z azix ,Output1 activate, when I command x axis, z axis is moving instead, only Y axis is working fine.  I have change the PC and also interface board, but the result is the same. Inputs are functioning good. The machine is behave like this in any out pins configuration.
  •  9,362 9,362
Re: Mach3 motor outputs issue
« Reply #1 on: February 20, 2018, 04:29:49 AM »
Hi AndreiD,
Could you please attach your .xml file.
This file is in your Mach3 folder and it is called <your profile>.xml (typically Mach3Mill.xml)
« Reply #2 on: February 20, 2018, 04:36:50 AM »
Tweakie thank you for reply, but after few install/uninstall of Mach3 , things return to normal.  I do not now where was the problem anyway.
  •  9,362 9,362
« Reply #3 on: February 20, 2018, 05:19:01 AM »
I am pleased you have it sorted.  :)
I was just concerned that you had posted a question 2 weeks ago and it had not received a reply.
