Hello Guest it is May 23, 2025, 02:40:55 AM
Author Topic: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA  (Read 97548 times)
Offline TPS
  •  2,578 2,578
Re: MACH3PLASMA LIMIT SWITCHES FOR G540/PROMA
« Reply #190 on: February 28, 2018, 02:31:22 PM »
deleted N100 toolchange not necesary.
sorry i modified N100 to N100 F80 to Keep the fedrate
Does the tool change code matter? It’s being generated by itself, but in MACH, my “ignore tool change” setting is checked. It has never been an issue
who knows ?
« Reply #191 on: February 28, 2018, 02:33:12 PM »
So leave THC on, and inputs active, but physically remove the inputs into my g540?
but disconnect only THC UP/Down inputs
Did this, everytbing is running smooth other than the proma actually making the inputs
Offline TPS
  •  2,578 2,578
« Reply #192 on: February 28, 2018, 02:34:50 PM »
can you please explain did not get this, sorry thats my bad english
« Reply #193 on: February 28, 2018, 02:38:28 PM »
I did what you said and it runs smooth but it’s  not actually controlling the Z height.
Offline Davek0974
  •  2,606 2,606
« Reply #194 on: February 28, 2018, 02:39:29 PM »
It shouldn't but in light of odd things going on, any odd code should be pulled i think just until its all working at least.
Offline TPS
  •  2,578 2,578
« Reply #195 on: February 28, 2018, 02:39:54 PM »
ok that means we know now that proma is sending z-axis down.
« Reply #196 on: February 28, 2018, 03:14:10 PM »
So maybe it’s a setting in my PROMA. I can’t  think of anything else..?
« Reply #197 on: February 28, 2018, 04:32:29 PM »
MACH is changing my Z zero on its own after the first m05 code.
« Reply #198 on: February 28, 2018, 04:34:15 PM »
It’s not this, i can watch the PROMA while the code is running, and there’s is no led indicator on the face of the PROMA. It is just simply MACH changing the Z zero before the cut is finished, or when the m05 line is hit.
Offline Davek0974
  •  2,606 2,606
« Reply #199 on: February 28, 2018, 04:45:31 PM »
Pretty certain Mach will not be doing it, something else, but not Mach, if it were then nobody would be using it and there are thousands of users.
