Hello Guest it is December 21, 2024, 09:43:30 AM
Author Topic: Auto zero with ESS not working correctly  (Read 22690 times)
  •  9,279 9,279
Re: Auto zero with ESS not working correctly
« Reply #10 on: April 03, 2018, 02:09:30 AM »
worked first time exactly right
It will not be ‘exactly right’ because there will always be some overrun (Z axis deceleration at the chosen feed-rate) and that line of code is intended to apply the correction but, if you are happy with the results then that’s all that is important.
« Reply #11 on: April 03, 2018, 02:49:15 AM »
Thanks for all the help, I'll probably be back onto ye when the sensors for my homing arrive and I get going on setting them up
Offline TPS
  •  2,536 2,536
« Reply #12 on: April 03, 2018, 03:04:35 AM »
I removed the line "Code "G0 Z" &ZProbePos"
try to replace it by I  "Code "G1 Z" &ZProbePos"
Looks like you machine is not able to follow G0 Speed.
« Reply #13 on: April 03, 2018, 03:30:03 PM »
I changed G0 to G1 and it worked lovely, I've backed up everything so I don't have to try and figure that out again
