Hello Guest it is March 14, 2025, 02:25:09 AM
Author Topic: SetToolX() documentation  (Read 5965 times)
« on: May 08, 2018, 04:21:48 PM »
Please could anyone point me to where the subroutines SetTool<X/Y/Z>() are documented?  I assume that they write the number in the brackets as an offset into the tool table entries for the currently selected tool, but where?  I cannot find any reference in the Wiki or elsewhere to how to use them.
Thanks in anticipation,
John.
Offline TPS
  •  2,558 2,558
Re: SetToolX() documentation
« Reply #1 on: May 09, 2018, 01:42:18 AM »
« Reply #2 on: May 09, 2018, 02:49:21 AM »
Aha!  Many thanks.  Doesn't seem to do quite what I expected, but I'll have a dig around in the document.
Thanks again, John.
Offline TPS
  •  2,558 2,558
« Reply #3 on: May 09, 2018, 02:52:36 AM »
what did you expect?
« Reply #4 on: May 13, 2018, 08:01:18 AM »
Hmm.  Well, what I would like if it exists is something where a value in a user-defined DRO (resulting from measurement and calculation) could be poked into a specified entry in the tool table for tool "N" (also defined in a DRO).  This must be possible because it is used in the standard turn Tooltable screen but how it works is to me obscure.  Any light on how to do it would be most welcome (if it's possible!).
Thanks, John.
Offline Davek0974
  •  2,606 2,606
« Reply #5 on: May 13, 2018, 10:26:18 AM »
Dim Tool
Dim MyParam
Tool = GetUserDRO(1010)
MyParam = GetUserDRO(1011)
SetToolParam(Tool, 2, MyParam)
This assumes you have added two DRO's - 1010 and 1011
Tool parameter 2 is the the tool length offset
For Mach3Mill:
1 = Diameter
2 = Z Offset
3 = X Wear
4 = Z Wear
For Mach3Turn:
1 = Tip Type
2 = Tool Radius
3 = X Offset
4 = Z Offset
5 = X Wear
6 = Z Wear
7 = Turret Angle
You can't alter tool zero.
« Last Edit: May 13, 2018, 10:29:11 AM by Davek0974 »
« Reply #6 on: May 13, 2018, 12:56:05 PM »
Dave, good input at exactly the right time as I'm rewriting my tool setting macro and you have just saved me hours - many thanks!  To make sure I understand the operative command is:
SetToolParam(<tool number>,<param type from your list>,<parameter value>)
Correct?
Offline Davek0974
  •  2,606 2,606
« Reply #7 on: May 13, 2018, 03:16:29 PM »
Yep
Don't forget to save the tool table after, its DoOEMButton(316)
« Reply #8 on: May 23, 2018, 04:26:00 PM »
Dave, just to repeat my thanks, as I've just got my tool setting macro working properly thanks to your input.
I can mount a tool, give it a number in a DRO, position it in the shoulder angle of my test bar of a known diameter, click "Measure Tool", and a minute or so later the offsets are measured and stored in the appropriate line of the Tool Table.  For me, a result!
Offline Davek0974
  •  2,606 2,606
« Reply #9 on: May 23, 2018, 04:35:48 PM »
Nice :)
